I am still doing a bit on the Pop even though it may not seem like it
Got the cover off today to drill the holes for the handbrake cables.
Looks like I'm going to have to shorten them.
Going to need quite a bit off by the look of it.
Doing this in bits on my phone, can't see how to put a photo on the write after it?
Cheers Tim W.
Got a little bit further with he handbrake cables at the week-end..
Made a couple of jointing pieces ready for the shortening.
Cut the inner and then shortened the outer, joined the outer with a small piece of dairy tube which I’ll heat shrink over when it arrives.
Joined the inner with my joining piece, which will be welded, galv sprayed then covered in heat shrink. This part runs in a ¾” tube so the joint will be fine in there.
Sorted, fit in pretty well.
Next job is sort out the calipers, replace the diff cover gasket get it all fitted and repainted.
That’s it for now, more when I do more.
Well done. Another job done then. I do admire what what you have done with no garage, just a little shed and the other problems you have had.
Good to see your still tinkering away at it.maybe this year you,ll hit the road.
Sent from my iPad using NSRA mobile app
It's set to private, only you will be able to view. I was thinking this afternoon where you had been and if there was any progress !
Well I got the Handbrake cables secured and freshened up the axle paint at the weekend, the red is more in keeping with the creamy colour the Pop's now going to be.
More when I do more.
nice to see your still chipping away at it Tim, good job on the handbrake
be quiet when you leave.... mr munn lives right around the corner
My Easter lockdown wasn't quite as bad as I thought it would be, managed to get the V8pop third break lamp mounted...
Also managed to get the wiper wheelbox mounted made some spacers for the rear and a front bezel...
Good progress Tim, you will need to trim off about 1.5" of wiper at the top as it will hit the window rubber in use.
http://www.case-design.co.uk
Thanks Mark, I'll sort it later when I have the proper screen in with the internal rubber, that's a polycarb screen with modern external two piece rubber.
Cheers Tim W.
Got a few more bits done over the weekend…
Made a gasket for the wiper wheel box escutcheon.
Then managed to mount the wiper motor out of sight behind the right-hand corner of the dash.
And I was lucky enough a few years ago to get a second hand Maradyne Hot Rod Heater…
I made a template and drilled the holes…
I need to modify my pedal cover to allow the drives side flap to open and make a bracket for the bottom fixing but other than that all is well.
Unfortunately, the demister pipe take-off is bigger than my old British (MG I think) demister set-up.
So, I made some adapters.
These can be bolted to the casing thanks to some M4 Avdels.
More, when I do more.
Good progress, that heater fits in nicely.
Cracking job Tim
