Page 11 of 83 FirstFirst ... 9101112132161 ... LastLast
Results 201 to 220 of 1642
Thread: V8pop's V8pop
  1. #201
    Quote Originally Posted by cossie pop View Post
    geeeez thought mine was tight sit in the arches nice you gonna cut the front wings ? are you going to use the wing/light supports still stop the wings bouncing about may raise the wing a tad with them on
    like em low
    Adie
    Yep sure am Adie, I think the lamp supports will just clear - fingers crossed.
  2. #202
    Quote Originally Posted by Rover V8 View Post
    Hi Tim,
    Great progress, they look much better once the sheet metal is on
    Shame about the wing clearance issues. Just a thought, when your on full lock youll need at least 2" clearance to stop you bashing the wing if you have to go up a kerb for example ??
    Wouldn't want to see that happen.
    You probably have considered this, but thought I would say just in case,
    Keep up the great work,
    Thanks for the heads up Mike, I intend to rev up my profiling tool again to get an accurate line for the modification. But that will be a while before I start doing serious body work.
    I was real supprised just how different she looked with the front back on, I think when you spend so much time looking at them without the sheet metal on, it sort of lifts you when it goes back on.
  3. #203
    Quote Originally Posted by v8pop View Post
    Tim,
    No worries, I know how easy it is to miss this sort of thing, I did think you would be on the case.
    Totally agree ref making it look like a car again, certainly does the trick
    Good luck,
    Mikes V8 Pop build
    IT'S ALL GOOD IN THE HOOD
  4. #204
    nice work tim but that is low will be nice to see what height once you put the engine in keep up the great work
  5. #205
    Tim are your front wheels 15" or 14" ???
  6. #206
    Quote Originally Posted by 53pop View Post
    Thanks Allan, the front coilovers are steel tubes drilled to the correct ride height, so if I've understood Kev (Kapri's) instructions right, it should ride as is when finished.
  7. #207
    Quote Originally Posted by Steve Lang View Post
    Steve the fronts are 15's with 155 80 tyres.
  8. #208
    I'm using the same but have a little more clearence as its a bit higher than yours.
  9. #209
    Oh right, I hope to get the cover right off at the week-end (weather permitting) and roll it across the drive to check the stance. So it may change a little bit yet.
  10. #210
    Got a bit of time on Saturday so I rolled her off the slabs and on to the drive to get a better look at the stance…
    I’m pretty pleased with that! I decided to turn her round to work on the steering without the now present sun in my eyes. I had to remove the front sheet metal any way so I did that as I’ve got hardly any lock with it on and then I took her out on the Queen’s highway (well the lane) for the first time in many a year.
    Started looking at re-fitting the original steering box.
    I then had a sudden thought, maybe now would be a good time to offer up the motor to see what type of steering issues I may have. I spent a bit of Sunday morning looking through my pile of RV8 bits to piece together a mock up block, heads and gearbox. It’s starting to feel like a real Hot Rod!!!
  11. #211
    Thumbs up
    thats sitting nice and low Tim maybe a tad tp low on the front like the way your keeping the original look to the build hope it stays dry for ya
    Adie
  12. #212
    Looks great Tim,
    Real glad you got lucky with the weather, sure is low but it ain't gonna be slow
    Mikes V8 Pop build
  13. #213
    well that looks great tim when you can see the hole car hope it stays dry for you so you can carry on the great work
  14. #214
    Tim,
    Are you 100% that your gonna profile the front wings?
    I think they will look odd if you do.
    Too thin on top in comparison with the 'bulk' of wing that is behind the wheel.
    Just my opinion of course.
  15. #215
    Adie
    Cheers Adie - I reckon she'll be OK that height. Yours aint so far off the ground mate, not according to that picture on your sig.
    Looks great Tim,
    Cheers Mike, Yep hopefully the sun's with us for a while.
  16. #216
    Thanks Allan - Let's hope.
    Quote Originally Posted by chris View Post
    Tim,
    Interesting comment Chris, and your opinion (as is other members) is always welcome. I do need to re-profile or something else in order to keep that height, but I see what your saying and appreciate the early warning before I bollax the wings. I will, as last time do a fair bit of planning and calculating prior to chopping them up. It's never easy is it?
  17. #217
    That sits nice and low Tim, once the sills are on it will give the impression of being even lower!!
    Hope you can sort out your clearance issues, all the best with progress.
    Nick.
  18. #218
    Quote Originally Posted by PortlandPop View Post
    Nick.
    Thanks Nick, fingers crossed mate.
  19. #219
    Tim,
    Johns looks similar to your stance, don't think he modified the wings ??
    Hope this helps,
    Mikes V8 Pop build
  20. #220
    Tim,
    Hope this helps,
    See what you mean Mike, maybe mine's a wider track, will have to bring me tape rule to Billing this year. Thanks, food for thought mate.
