Page 13 of 153 FirstFirst ... 311121314152363113 ... LastLast
Results 241 to 260 of 3046
Thread: V8pop's V8pop
  1. #241
    Quote Originally Posted by Steve Lang View Post
    Tim it seems from the pics that the tierod is going to hit the pitman arm when the front suspension starts to compress ???
    Well noticed that man, I have just over 3/4"of clearance but 1 1/4" of suspension travel. The set intend to put in the tie rod for the full lock foul will also solve that problem - Hopefully!
  2. #242
    1.25" isn't a lot of travel Tim, With weight shift on braking i would expect it to move a bit more than that
    Quote Originally Posted by v8pop View Post
  3. #243
    Oh! Looks like I've got a bit more learning to do. My intention was to have 1.25" travel on the coilover then onto the bumpstop Steve, How much clearance should I be looking for mate?
  4. #244
    Depends really but i like to see 2-2.5" minimum, I take it you have a bumpstop on the coilovers ??? I'm not keen on these as i prefer to use a chassis mounted stop. Most streetrod suspensions are way over sprung so don't move that much but in an emergency stop situation can move a lot further than you imagine.
  5. #245
    Thanks for that Steve, I will sort the tie rod to give that sort of clearance. With regard to bump stops I intended to do the same at the front as I did at the back, use a bolt on along side the coilover ones. Once again thanks mate.
  6. #246
    I know a lot of people had a wet week-end but I seemed to get away pretty light Sunday was the worst day! Saturday saw me out with the cutting disk starting to plate up all the modifications to the front of the chassis.
    First was the passenger side re-shaped rail.
    Next on to the rail ends where I had to re-shape to miss the front sheet metal.
    Then I moved on to the steering box mount outer side.
    Then the Inner side.
    And finally the boxing plate, first I shaped the bit to join to the mounting bracket
    Then got on with some metal forming to make the finished shape.
    Still no sign of any rain so I got the MIG out and welded the front rail plates in.
    Then moved over to the passenger side rail.
    Then it was round the steering box, I tacked the outside plate.
    Then the inside plate and boxing plate.
    Then fully welded both the bracket and the plates.
    That was me done until Monday morning, then I bolted the front axle and steering on.
    That’s it for now, next job is to put that RV8 in the remaining space! More when I do more.
  7. #247
    NSRA member Rover V8's Avatar
    Great work as usual Tim, glad you got some good weather, bleedin weekend looks cold again though
    Good luck,
    Mikes V8 Pop build
    IT'S ALL GOOD IN THE HOOD
  8. #248
    Dec 2007
    Nice work there Tim, that's a few more jobs ticked off..
    may the sun continue to shine!
  9. #249
    Quote Originally Posted by Rover V8 View Post
    Good luck,
    Thanks Mike, yeah Saturday don't look too special mate.
    Quote Originally Posted by PortlandPop View Post
    Thanks Nick, must admit it feels good to finish the front end and move on.
  10. #250
    I have managed to do a bit on the Pop!
    You know, that moment where you sit the motor in the freshly made hole in the bulkhead! Yep she’s starting to look like a Hot Rod.
    You can see by the way the block sits at that jaunty angle that the steering box/column will have to be removed for now.
    The next job was to make a bit of room inside.
    I didn’t see any point in cutting the original “K” member out only to replace it with another that I had fabricated so I decided to relieve it as necessary then box it later.
    Now she sits in the hole all square and level.
    I thought I should bolt the headers on as well at this point.
    I bit the bullet and cut the steering box free from the column!
    This is my engine mount of choice, I think it’s a Landie one.
    My card template.
    As used for trial and fit.
    Convert that into some pieces of 5mm P&O.
    With a bit of a hammer and prep you end up with this…
    Out with the welder.
    And here’s the finished two.
    With the engine mounts on.
    Passenger side on
    Drivers side on
    Next I will sort the gearbox mount so I can get it all set and level prior to making the chassis mounts, more when I do more.
  11. #251
    Hi Tim,
    Good work as usual, it's good to see that you are considering the motor, that's good progress
    Mikes V8 Pop build
  12. #252
    Tim don't forget to drill a drain hole in them mounts.
  13. #253
    NSRA member chris's Avatar
    Jan 2005
    Tim,
    I think the motor needs to be mounted with rake toward the back,something to do with oil,but cant remember why.
    Cant remember what degree of angle it needs to be either.
    Im sure John will remember...
  14. #254
    Set the carb flange level Chris.
    Quote Originally Posted by chris View Post
    Tim,
  15. #255
    Jan 2005
    Ah,second look at the pics,my mistake,as you were...
  16. #256
    Cheers Steve, Good job someone's looking after me!
  17. #257
    Hi Tim,
    Thanks Mike, been awa froma PC for a few dayz.
  18. #258
    Cheers Chris.
  19. #259
    I have been able to do a bit on the Pop lately; I whipped the bell housing off the engine and put it back on the gearbox so I could get the gearbox bolted to the engine.
    In order to make sure I was not too far forward (space for a radiator would be nice – I still remember the CC Marina pick-up) I quickly put the front panels on.
    Happy with that I set about mounting the tail end of the gearbox
    With the box section relieved and clamped in place, I sat and decided how to join the two together..
    I came up with a sketch and some plates.
    This is what I came up with.
    Happy with that I trimmed, drilled and bolted them to the cross member.
    Next was the central rubber mount, this I recessed into the box section to make it look a little tidier.
    Then I tacked the cross member in place – job’s a good ‘un.
    Next it was onto the near side chassis engine mount, the mounts were never going to be the same as the off side has to step round the steering box. Started with an hour of cardboard cutting.
    Taking shape now.
    Kit of parts from my trusty sheet of 5mm P&O (my ears were ringing after chopping those out).
    All tacked up ready for a trial fit. Note the drain hole, despite what my missus say’s you only have to tell me once!!
    It only fits.
    That’s it fully welded, as I wait for it to cool down.
    Job done, tacked on to the chassis and taking the weight of the engine.
    Now it’s on to the off side, so I started me Blue Peter again.
    I then realised that the spring cross member was going to have to go. I had often thought it would but was always reluctant to chop it out just in case I needed it. So I cut a bit of tube as a spreader bar to put in the end of the rails.
    Out with the cut-off wheel again and there it is gone.
    So I was able to finish my cardboard mock up
    Back to the shed and the 5mm P&O with a bit of 25 x 6 black flat thrown in for good measure.
    All tacked up ready to trial fit.
    That seems to do the job.
    So it gets fully welded.
    Fitted back in place once it’s cooled and tacked to the chassis.
    All good on the level front.
    And there she sits.
    Next job is to take it all out again and fully weld the brackets to the chassis, while I’m in there I will box the rest of the chassis as well.
    That’s it for now, more when I do more.
  20. #260
    Sep 2009
    Very good work as allways
