Page 51 of 83 FirstFirst ... 41495051525361 ... LastLast
Results 1,001 to 1,020 of 1642
Thread: V8pop's V8pop
  1. #1001
    looks good Tim, progress should be good now weather is better.
  2. #1002
    Thanks Mark, yeah and lighter nights are just around the corner as well.
  3. #1003
    Tim use flapper disc their easier on the surface and don't leave great indents marks on the surface mate
    40 ,course ,60 mid course then 80 grit I use the 60 there about right mate just advise mate
  4. #1004
    Quote Originally Posted by spokido View Post
    Always happy to have advise Wade, are they the ones with pieces of abrasive that are over layed like tiles? If so I have a free issue trial pack in the shed I'll give them a burn.
  5. #1005
    Yes tim they are easier on the steel but do the same job and will move better over body contours etc medium grit 60 pr the 80 are fine and with some practice leave a polished finish if required .
    hope this helps mate
    They are also safer than a disc in many cases will puts some photos up soon
  6. #1006
    nice work tim coming on a treat
  7. #1007
    Quote Originally Posted by 53pop View Post
    Thanks Allan, hope to get a bit more done this week-end mate.
  8. #1008
    Excellent work indeed Tim. Hats off to you...
  9. #1009
    Quote Originally Posted by newboldspeed View Post
    Thanks mate, much appreciated.
  10. #1010
    Finally got a bit more time on the rear quarter, firstly I marked out the number plate recess.
    Then it was off to the shed to sort out the infill plate, starting with a bit of 18 gauge Zintec.
    Then on to the press…
    Didn’t have any segmented tooling so I used a bit of 6mm plate.
    Now I’m back to the Pop and chopping out the valance, I know I put that bit in earlier but it’s good practice.
    And tacking in the recess plate
    Fully welded.
    And a lick with the grinder, with the “Flapper disk” Wade.
    I’m now at a point where I’m going to roller a drop of Epoxy primer on the back to protect it so I got a few bits out of the car and cleaned them up ready for the excess paint.
    And out comes the roller.
    Couldn’t resist putting it all back together to get the overall look. The boot lid needs panel fitting proper but for now I’m concentrating on getting old rust out and new metal back in, so that will come later at body prep time.
    Now working on the inner tool tray boot floor area before incorporating those missing inner arch ends.
    That’s it for now, more when I do more.
  11. #1011
    NSRA member Flamin Black A's Avatar
    Apr 2005
    looks good in black. Tin
  12. #1012
    Gives you a big boost when some paint goes on doesn't it?
    Looks almost finished
  13. #1013
    That looks spot on Tim
    18 'til I die
    My Intro
  14. #1014
    lookingh well tim nice to see it in one colour makes a big differance,one question where are you going to mount there number plate lights and what type will they be
  15. #1015
    looking very good Tim. I bet it's better than you expected??
  16. #1016
    NSRA member yjohnb's Avatar
    Apr 2012
    That looks really neat, the extra depth on the valance works well, nice done Tim
  17. #1017
    coming on mate nearly there
  18. #1018
    Quote Originally Posted by Flamin Black A View Post
    Thanks Pete, that silver at the top's the cover mate I'm not copying.
    Thanks Mark, yeah it does, if only mate.
    Quote Originally Posted by MoreCubes View Post
    Thanks Ian, you were a good mentor mate.
    Thanks Allan, I intend to use those LED bolts mate, they seem to work quite well and I've not heard of anyone having problems running them.
    Quote Originally Posted by the maxster View Post
    Thanks Marcel, I must confess to being pretty chuffed with the result mate.
    Quote Originally Posted by yjohnb View Post
    Thanks John, Yeah turned out well in the end mate.
    Thanks Wade, I so wish it was mate, especially now the suns out.
  19. #1019
    Tim my car is off to paint and believe me I miss not being able to dive her in this weather you,ll be done before me mate
  20. #1020
    Quote Originally Posted by v8pop View Post
    Thanks Allan, I intend to use those LED bolts mate, they seem to work quite well and I've not heard of anyone having problems running them.Cheers. Tim W.
    That was going to be my suggestion.
    18 'til I die
    My Intro
