Is there another colour Tim ?????
18 'til I die
My Intro
Hi Tim,
Really good to see the progress your making, the rear end turned out real good, as I knew it would, looks good in the epoxy, and the trans tunnel, top jobs as always, looking forward to the next update,
come on tim, time's ticking. what you been up to and we need pics. neil.
Hi Tim,
You might get away with some pics of the kitchen if you use some of the left over trim to fix your fuse board to
Come on Mike - you can do it. At this rate you're going to beat Mark H****y for the longest build !
18 'til I die
My Intro
My time on Amy’s Kitchen’s finished early Saturday afternoon so as soon as the grass was cut I was on that old Pop again.
In sorting out the ar$e end I couldn’t help think that the exhaust hanger cross member was in the wrong place so after a bit of thought (unusual for me) I chopped it out. And replaced it with this…
Giving me a bit more usable space, so I got out some 18 gauge sheet and fashioned a tray to fit between the pipes.
And there it is in situ waiting to be welded in place.
That saw the end of Saturday, so come Sunday morning I needed a quieter job. Out with the cereal box again for the time consuming part, making templates for the side pieces. Drivers side first.
And then the passenger side.
Into the back of the shed for some more 18 gauge Zintec and I’m away.
One cutting disc and some annoyed neighbours later I’ve got these.
Out with the press!
And this is as far as I got before rain and Lunch stopped play
Hopefully I’ll get them finished off in the week and trial fit them ready for welding.
That’s it for now, more when I do more.
well done Tin, neat solution
