Wot Neil and Dusty said.
Good work on the wings Tim.
Thanks Rich, got a bit to do yet but the're coming on.
Thanks Steve.
Thanks Dusty, good point and the more I look at it the more I know you are right. Just a glitch mate I'll be back on the other wing next week-end.
Thanks Mark, aye forward planning indeed!! I'll remember for next time!
Yep makes sense Neil.
Thanks Paul wings it is then.
Not much of an update as I’m still struggling for Pop time but have managed to get a bit done on the other wing, looks like I did the best one first…
Based on the rolled edge problems I’ve borrowed “Jenny” from work for a bit.
So I’ll just do it a bit at a time until it done, started with the Mirror and indicator holes.
Cleaned the holes up and clamped the patches in
All welded ready for cleaning at my next outing.
I’ll put some effort into that mounting flange next time I’m out there.
That’s it for now, more when I do more.
looking good tim id keep the wings mate, they look naked without em
be quiet when you leave.... mr munn lives right around the corner
Blimey, the tin worm definitely keeping you busy!
You've had your work cut out and looks like youve been making some great progress, keep at it.
John
Any updates Tim???
http://www.case-design.co.uk
WellI finally got some dry spare time… I had this to post last week but I up-gradedto Windows 10 (don’t ask) so I’ve had some IT issues to sort!!!
WellI’ve been chopping out some of the old mounting flange and welding inreplacement parts.
Nowthe bottom edge of the wing has seen some re-work over the years and this iswhat’s under the paint
Ican’t make a suitable bead rolled edge to match the existing or have tooling totrap a round bar in either so I’ve come up with an alternative plan. Firstly Icut a piece of 18 gauge Zintec to match the profile.
ThenI rolled a step.
ThenI got a 11 x 6 strip of mild steel and bent it to the wing contour.
ThenI clamped it up and welded it in place.
Next job is to clean it all up and weld it on to the bottom of the wing
Cheers.Tim W
That will stiffen the wing up a treat!
Very nicely done Tim, your approach to the whole build shows what can be done with ingenuity and hard graft.keep at it
John
good to see you doin a bit Tim, nice work
Got a bit more done, cleaned up the new wing bottom, and the rest of the repairs.
Then I marked out the wing ready for the replacement end
And off it comes
Clamped it on ready for tacking
I got one of the lads at work to press me a new steady strap
So I tacked the wing and welded it on to keep it from going out of shape when I fully weld it.
After cleaning it up I forgot to get a photo so I nipped out to the shed in the rain on Sunday and took this.
Not much more and I’ll be able to paint it and bolt it on!!!!
Cheers.Tim W.
Nice job!
Great Job Tim! Brings back memories
Zetec powered pop ON THE ROAD!!!
Quality work as always.good to see you back on it.
