Page 84 of 84 FirstFirst ... 3474828384
Results 1,661 to 1,667 of 1667
Thread: V8pop's V8pop
  1. #1661
    I am still doing a bit on the Pop even though it may not seem like it
    Got the cover off today to drill the holes for the handbrake cables.
  2. #1662
    Looks like I'm going to have to shorten them.
  3. #1663
    Going to need quite a bit off by the look of it.
    Doing this in bits on my phone, can't see how to put a photo on the write after it?
    Cheers Tim W.
  4. #1664
    Got a little bit further with he handbrake cables at the week-end..
    Made a couple of jointing pieces ready for the shortening.
    Cut the inner and then shortened the outer, joined the outer with a small piece of dairy tube which I’ll heat shrink over when it arrives.
    Joined the inner with my joining piece, which will be welded, galv sprayed then covered in heat shrink. This part runs in a ¾” tube so the joint will be fine in there.
    Sorted, fit in pretty well.
    Next job is sort out the calipers, replace the diff cover gasket get it all fitted and repainted.
    That’s it for now, more when I do more.
  5. #1665
    Well done. Another job done then. I do admire what what you have done with no garage, just a little shed and the other problems you have had.
  6. #1666
    NSRA member dwgunn159's Avatar
    Apr 2008
    Good to see your still tinkering away at it.maybe this year you,ll hit the road.
    Sent from my iPad using NSRA mobile app
  7. #1667
    Quote Originally Posted by brading View Post
    Thanks Paul, yeah I've often said either I'll finish it or it'll finish me
    Quote Originally Posted by dwgunn159 View Post
    Aye, still at it Denis, it would be nice if I could, I've altered my build list to truncate the the time table
