Hi all,
My build is a 58 Pop I bought as a started project, It was fully stripped and primered when i got it. I have since built a new chassis and full cage from 80mm x 40 mm box section and 1-5/8th CDS tube which is almost complete now as just some final bits to finish weld.
The body has had the usual repairs carried out, rear valance, A & B pillar bottoms. I've also fitted an Astra estate roof into the existing hole, modded the rain gutters and completely rebuilt the front bulkhead and radiused the rear arches so I can fit new tubs which i will soon be fabricating.
The engine is a 354 Hemi and will have forged 10.5 -1 pistons, high lift cam. steel crank,rebuilt heads with a high rise inlet with 2 x 4 barrels (not sure which yet) block huggers, and no doubt plenty of alloy dress up goodies.
The box will be a TH 400 with a reverse pattern shifter and 2500 stall TC.
The rear will be a shortened, 5 linked, 9" with 31 spline axles and locker with 3.7 gears and disc brakes.
The front is shortened leda struts with m16 calipers with RS 2000 vented discs all connected with homemade links and spherical rod ends.
Steering possibly Fiat 124
Interior may end up in full ally, not sure yet (may be carbon fibre)
Wheels are Weld Pro Stars 12 x 15 & 3.5 x 15
Things have slowed down a little as I'm waiting for a load of parts coming in from the states and it takes an age.
I haven't posted any pics as it won't let me due to the file size? but the car and it,s progress are on Mark Harley's website (Blackpop racing) in the garage scene. (Thanks Mark)
