Early ford front end parts+safety hubs
Front end assembly comprising-- 32 beam,32 spindles with weld on LHD steering arm (have a rhd spindle if you want rhd) ,Later model heavier duty split wishbones,reverse eye spring,track rod (not in pic),new perches + shackles,good kingpins+bushes,lower shock mounts and tube shocks £375 SOLD
32 split wishbones bit dinged but straight + usable,no end bungs fitted £55 pr SOLD
A, 32-34 front spring,has lots of leaves wants half of them removing £45
Model A front brakes unused relined shoes + pretty good usable drums £65pr SOLD
Safety hub retainers for early ford rear axles (stops wheel coming away if you break a half shaft) £30 pr SOLD
can be picked up from Cheltenham or delivered to swap meet,safety hubs could be posted. Thanks for looking,Chris
Reason: correction
