Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 201 to 220 of 221
Thread: One of these days T Truck
  1. #201
    NSRA Committee Knowledge's Avatar
    Apr 2004
    Continued....Name:  20200516_124156.jpg
Size:  72.3 KBName:  20200516_121626.jpg
Size:  76.7 KBName:  20200516_124148.jpg
    Sent from my SM-T810 using NSRA mobile app
    My Intro '
  2. #202
    Neat work, very clever.
    Quote Originally Posted by Knowledge View Post
    Sent from my SM-J530F using NSRA mobile app
  3. #203
    Apr 2004
    Amongst all the laser cut parts for the locks came the bits for the kick down linkage. With my seating position beeing ahead of the engine it makes sense for the throttle cable to approach from in front. The bell crank has a ptfe lined bearing in the centre with a shoulder bolt to rotate on. Link has reft and right hand threads for adjustment. Cable I should point out is just poked in as I need to sort the peddle end yet so can't set the length.Name:  20200523_114152.jpeg
Size:  106.3 KBName:  20200523_114219.jpeg
Size:  83.0 KBName:  20200523_113740.jpg
    My Intro '
  4. #204
    Apr 2004
    Missed oneName:  20200523_114316.jpeg
    My Intro '
  5. #205
    Apr 2004
    Trying out ideas....Name:  20200531_141851.jpeg
    My Intro '
  6. #206
    Cant't beat a bit of "Blue Peter" engineering mate. She's coming on well.
  7. #207
    looking good i recognise the carb linkage from somewhere
  8. #208
    That's one of those new-fangled flat face dial ones, isn't it? Hope you get the wiring sorted out for them, I dare say you'll need a circuit board!!
    MisteR Tee
    My Intro My website my cars
  9. #209
    Apr 2004
    No, its a 40 Ford direct replacement dash. I printed it at 1:1 scale to see how it looks. From what I saw it is self contained and has one plug in the back and the required sensors. Should hope so at over $800.
    That said I may stick with cream backed art deco round dials as looks more traditional T style.
    My Intro '
  10. #210
    Sorry that my irony went over your head Stephen, I was referring to the fact it was a paper printed one stuck on your dash!!!
    MisteR Tee
  11. #211
    Apr 2004
    Ah! See i took what you said at fascia value.
    My Intro '
  12. #212
    You'de better make a 'dash' for it after a comment like that! before someone 'clocks' you 'guaging' thier reactions
  13. #213
    you could be 'instrument'al in their down fall
  14. #214
    Apr 2004
    Yay! Locks finally finished. Mini bear claws from Pop Browns, laser cut blanks created using CAD folded and welded. Return springs from a house door handle. And levers from a BMX as internal handles. Taken about two weeks to sort completely. Door panel will cover the lot leaving just the release handle and had hold (painted black).Name:  20200613_113051.jpeg
Size:  80.8 KBName:  20200613_113120.jpeg
Size:  107.6 KBName:  20200612_184023.jpg
Size:  81.4 KBName:  20200612_184303.jpg
    My Intro '
  15. #215
    They fit in nicely mate.
  16. #216
    Apr 2004
    Dress up items have arrived. You'll get to see where it all goes as time passes.
    Thanks Ged Sant - http://www.geds-shed.co.uk/
    My Intro '
  17. #217
    Apr 2004
    I have two sets of spinner covers, but neither gave me that contented feeling, that 'yep that's it' buzz. So I designed these.Name:  20200616_165701.jpg
    My Intro '
  18. #218
    Apr 2004
    Having modified the Corsa column it was time to sort how it bolts into the car. A bracket sorted to hold the lower section it was time to think about the top. Now a Corsa like most modern cars has a tilt column but I figured this would be too hard to keep. Not one to shy away from a challenge I set too and carefully removed the bracket from the tilting piece and welded this to the section of VW column used. Then after extensive metal surgery the fixed bracket now bolts to the lower section's mount.
    There is still lots to do as I need a coller inside to set the VW top bearing and a very large 'boss' to fit under the T wheel that will click off the indicators, and a column release lever.
    I am wondering if I've set a new record for the most models/makes used in a single steering system? Let me see... Model T wheel, to home made shaft, to VW 1302 beetle column top, to Vauxhall Corsa C electric assisted column, to a hybrid Vauxhall/VW 1302 UJ, to VW LT van box to turn the steering 80 degrees, to home made link shaft partly using a piece of Ford Fiesta steering, to (finally) a modified Ford Cortina Mk4 rack..... phew!!!Name:  20200624_173328.jpg
Size:  83.2 KBName:  20200624_173341.jpg
Size:  85.0 KBName:  20200624_173346.jpg
    My Intro '
  19. #219
    Corsa column is available without tilt.
    Nice work.
  20. #220
    Apr 2004
    Oh! Looks like I lucked out then because I didn't search for a tilt one.
    My Intro '
