Results 1 to 13 of 13
Thread: Various early Ford and Hot rod parts
    Various parts for sale, can't get pics to load up, so if anyone is interested I can e-mail pics to them.
    '40's Ford spindles, unmolested fitted with new kin pins and reamed bushes. £175 SOLD Nige
    Pair of bolt on dropped steering arms, 1 3/4" £35
    Bolt on steering arm, the one the drag link bolts to, new. £15
    Front shackle kit, new. £15 SOLD - Hotrod57
    Stainless '28/'32 firewall support rod brackets, new. £10 SOLD Erwin
    Stainless lower shock mounts, used to roll around garage. £35 SOLD Daly
    2 inch spring liner, black, 20ft £10
    1 3/4 inch spring liner, black, 10ft. £5
    Angled short Moon breather, new. £20
    '32 cowl vent, top replaced in the '70's not used since, original inner frame and chrome handle, comes with new spring and rachet. £45 - SOLD Erwin
    Pair of rear axle brackets, with gussets, to fit transverse leaf spring. £30 - SOLD Pete
    '32 Boot lock, new. £10 - SOLD Erwin
    '32 Original firewall, needs some work on the top lip and feet. £360 - SOLD Rik
    '32 Original handbrake. £40
    '32/34 English R/H/D steering column/box. £110
    Cast ally brake scoops, with fixing bolts, unused. £35 - SOLD Rik
    Taking all this plus more to the swop meet.
    Cheers, Chris... 07709260013
    You only made one mistake, you trusted me........
    Hi Chris,
    please put me down for:
    And are you the same Chris who's joining LordPurple to the swappie ?
    cheers
    erwin
    NSRA member Dave's Avatar
    2nd dibs on the cowl vent please it 32vertex happens to change his mind
    ...but is it steel?
    Front shackle kit please, will be at swap meet
    FoMoCoMoFo
    NSRA member Mel's Avatar
    Pm'ed you about the lower shock mounts.
    Replied to all who have mailed
    Erwin - cowl vent, boot lock rod brackets, not me with LP, I'll be in red VW van mobile number now on bottom of ad
    Hotrod57 - shackles
    Thanks, Chris...
    Steering box
    Chris - pm'd you re steering box Keith
    are the cast ally brake scoops the type that fit '40 ford backing plates? If so I will take them.
    Sorry 29stude brake scoops sold in the last hour.
    Chris....
    second dibs if matey changes his mind, please.
    Ok, will do.
    Daly,
    You have mail
    Cheers, Chris...
    Quote Originally Posted by 29stude View Post
    I keep these new if any good
    Miles
    miles@jackhammerspeedshop.com
    www.jackhammerspeedshop.com
    OFFICIAL DEALER for HOT ROD WORKS. SPEEDWAY MOTORS, MOONEYES, LIMEWORKS, HAYWIRE, GENNIE SHIFTER, DYNAMAT, TECHNOSTALGIA, AUTOLOC, PERTRONIX, PATRIOT EXHAUST, C&G EARLY FORD PARTS, OTB GEAR, SACREMENTO VINTAGE FORD, LOBROW KUSTOMS and many more.
