steering rack sugestions please
for my project
http://www.nsra.org.uk/newforum/showthread.php?t=393
im after a rack that will fit a cortina track also will need track rod ends to fit the rack and the cortina steering arms, the rack will need to be one that works from behind the xmember
any ideas
ian
Left hand drive cortina/taunus rack flipped upside down? Probably get one of ebay.de
Matt
anything else that will fit?
I was in the same situation as you and bought a new mk1 Fiesta rack (£7 off EBay). Rear mounted & about 4 inches narrower than the Cortina. Not sure if its compatible with the Cortina track rod ends as I never got round to doing it!
Moderator
Most front wheel drive have a rear mounted rack, usually on the bulkhead, the problem being the more modern the car it usually has power steering of somesort, best bet is a tape measure and a wander round a friendly scrappie !
