Chrome & Stainless wheel nuts M12 x 1.5mm pitch IE:Cortina MK3/4/5,Granada etc,tapper is standard 60 degrees for steel wheels,or alloys with tapper seat insert.
Chrome nut, (on the left)
21mm socket size,thread is 31 mm deep ,
Two sets available only.
£12 a set off 16,or £15 a set of 20
Stainless steel outer lined nut (has M & I stamped on the top) this is a galvanised steel nut with a Stainless sleeve permanently fixed to it,so no rust.
19mm socket size,thread is 30mm deep,
£18 a set of 16,or £21 a set of 20
Collect from my home, Hot Rod Drags,(or will post plus P&P)
Note these are OE spec nuts and not after-market,they have been fitted to a car and then removed without the car being used,so some of the nuts may have veryvery small marks on them where a socket has been used,only what you would do yourself while fitting,there is no rust and are effectively as new.
Polished cast ally hand grenade shifter,with insert for 10x1.5mm thread,could be rethreaded,trigger has been secured (i.e. does not rattle)£20
