Results 1 to 3 of 3
Thread: 1929 Ford Model A Pickup £15,000 SOLD
    For Sale my 1929 Ford Model A Pickup
    £15,000
    repro chassis changed to lock stock original.
    Rover 3.5 with balanced bottom end and 9.5.1 pistons ... hurricane street/strip cam and hydraulic lifters.
    500cfm exelbrock carb with vsc secondaries ..... borg warner 65 auto box with lokar shifter ... jag radiator .... mustang rear end ... 32 drilled front end with 32 spindles 40s Ford drums Pete n jakes shocks .... 3 piece rotlieb hood ... fenland rod and custom body .
    SOLD
    NSRA member dwgunn159's Avatar
    Apr 2008
    A cracking hot rod,wish I had the money.
    NSRA member Fatguyz's Avatar
    .........but more info for you all. Thanks to Dave Biggadyke for scanning the original article that contained a lot of the info a buyer may ask
    32 rails Pinched at front and other chassis parts rebuilt by Steve with new crossmembers and the usual detailing that Steve did.
    70 Mustang rear end with stock brakes.
    Front end is undropped and drilled 32 beam with transverse spring, original 32 spindles 40 Ford drums and split chromed 32 wishbones. Original Buick fins and Pete n Jake shocks.
    Body cab is a Fenland Rod n Custom item with the pickup bed fabricated by Steve and a Rotlieb 3 piece hood and chrome grille shell.
    Auburn repro dash, Dolphin gauges and a 1941 Arvin heater.
    Engine is a 3.5 RV8 with balanced bottom end, 9.5.1 pistons, hurricane street/strip cam hydraulic lifters and an Edelbrock 500 vac sec carb.
    Borg Warner 65 with Lokar Shifter.
    Jag Radiator.
    Custom built Ali fuel tank.
    4 x 15 Radirs with 5.60 Cokers on Front
    8 x 15 Radirs with 8.20 Cokers on Back
    Gary Kybert interior
    ........hope this helps ��
