Stainless 4 bar set up, adjustable rod ends, polly bushes, cross member with prop loop, bars are 21 / 23" long adjustable,the bolts are 5/8" dia, the axle brackets can be supplied to fit 9" or full size 8" axles (3" dia),uk ford 2 1/2" dia & 3 1/4" explorer axle.
the rear bracket have 3 position shock mountings to take 5/8 dia bolt shock mounts.
Polished stainless @ £395.00
CDS Kit @ £345.00
