Results 1 to 6 of 6
Thread: 1936 rear
    NSRA member newboldspeed's Avatar
    Jun 2010
    1936 rear
    1936 Ford rear end no brakes. Axle ends taper & threads all good turns over freeley not opened up to have a look @ R&P.
    £424ono
    Feb 2018
    Quote Originally Posted by newboldspeed View Post
    £424ono
    Interested. Does it come with wishbone, torque tube etch?
    Where are you located please ?
    Jun 2010
    It's just the axle as described.
    No brakes "backing plates or hubs"
    No torque tube.
    I'm in Chesterfield Derbyshire.
    Thx
    Jun 2010
    R&P
    Ratio.
    Turned pinion & shafts rotate 4 times.
    Looked @ ratios for Ford.
    Ratio is 4:11
    Hope this helps.
    - - - Following new post was merged to prevent 'bumping' within 7 days - - -
    Ratio.
    Ratio is 4:11
    Hope this helps.
    Jun 2010
    Btt
    Jun 2010
    Thx
