Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 72
Thread: The quest to redress..
  1. #21
    If you're after a intank electric fuel pump i highly recommemd the Aeromotive phantom pump. Whether it be EFI or Carb. The installation was so easy.
    Comp cams stage 2 truck cam installed, comp cams adjustable timing set installed.
    Build it. Break it. Fix it. Drive it.
  2. #22
    That's a nice pump.
    I want one of these engines
  3. #23
    NSRA Committee Knowledge's Avatar
    Apr 2004
    That's a nice pump.
    You only just finished....already he wants to change it...lol
    My Intro '
  4. #24
    Apr 2004
    For the record Jake how long is that pump setup? (Min depth of tank).
    Edit. Its ok i googled it. 17inch long. But Eeeek. $441.
    My Intro '
  5. #25
    Quote Originally Posted by Knowledge View Post
    Edit. Eeeek. $441.
    Take it you found out hahaha
  6. #26
    $441 is fine for a pump setup that'll feed a turbo v8. The last thing you need is a lean mixture because the pump can't keep up. It'd be a lot more expensive then for sure.
  7. #27
    Horsepower does not come cheap.
  8. #28
    The 4L80E showed up on Friday so it was time for a test fit and set up new motor mounts and trans mount. It fits extremely well! Shouldn't have to alter the transmission tunnel so that worked out in favour!
    Now just to paint the firewall and final assembly can begin Name:  20181130_205037.jpeg
Size:  60.1 KBName:  20181202_105201.jpeg
Size:  56.5 KBName:  20181202_112832.jpeg
Size:  66.3 KBName:  IMG_20181202_144918_605.jpeg
  9. #29
  10. #30
    Nice.
    X2
  11. #31
    Plenty of room in that engine bay !
  12. #32
    That looks great, well done...
  13. #33
    We finally have the engine in place for the final time. Firewall has been repainted and a mass of 42 holes welded up.
    Had a unforseen problem when i came to pull the torque converter up to the fly wheel... PCD didnt match. So back off the flywheel came and a quick redrill on my Mill.
    Original 3 on the tree collumn shift converted to automatic with a Lokar shift linkage and some welding.
    ECU mounted with all wiring terminated with many hours of head scratching getting it to work with my Clifford Alarm/Immobiliser as they wont supply any technical drawings to joe blogs!
    Next step is to get the exhaust fabbed up and turbo mountedName:  20190105_153429.jpeg
Size:  70.3 KBName:  20190105_153420.jpeg
Size:  69.5 KBName:  20190106_113804.jpeg
  14. #34
    Very nicely done, keep up the good work.
    John
  15. #35
    Great job there Smithy, keep up the good work!
  16. #36
    Couple hours free at work today so i made a start on some of the exhaust pipework for the turbo. Made from 304SS Tig welded and back purged.
    Even managed to get the turbo mounted and made a cut out for the intake side.
    Next to make is a cross over tube and wastegate take off Name:  20190122_142350.jpeg
Size:  42.2 KBName:  IMG_20190122_183029_651.jpeg
Size:  108.1 KBName:  IMG_20190122_183029_652.jpeg
Size:  104.1 KBName:  20190122_182850.jpeg
  17. #37
    I'm assuming you are going to run twin turbo's?
  18. #38
    Just single, will build a pipe from driverside bank into that 90 bend
  19. #39
    Well done on the CC feature.
  20. #40
    Quote Originally Posted by rem View Post
    Thankyou, i am yet to see it!
