I broke it again! This time ive lost reverse!
4L80E apparently has a weak spot and reverse band happens to be it!
Did a show last weekend and have another this weekend so i shall be taking the trans out next week to investigate. Should be an easy fix i guess.
On the other hand the truck is doing extremely well, after i previously lifted the heads ive changed the lifters out to new LS7 lifters, LS9 head gaskets to drop the compression down a little and installed head studs.
Ive done just over 200 miles in it so far running at around 20psi boost and have had zero issues. Only issue i could say was terrified passengers with no seat belts! Ive since installed a set of sparco 4 point road harnesses to keep us buckled in haha.
Any how heres some pics from last weeks show...
The show is renowned for their exits! (Closed private road at the organisers farm)
Build it. Break it. Fix it. Drive it.
