looking for some SW gauges and wondered if anyone had any sitting about not being used. looking for a speedo 3 3/8 along with water temp, oil pressure, voltage? fuel gauges - these need to be 2 1/16 or 2 1/8
cheers
cheers
Your emotions will always interfere with your sense of truth
here's a start https://www.rodsnsods.co.uk/forum/st...counter-549775
unfortunately they are the wrong style Neil.
Hi Mark
are you looking for the set from an MGB ?
there is a set in my local scrap yard , i can send you photos on saturday as i am going in
cheers RAy
Ray I thought MGBs used Smiths gauges?
I have an oil pressure and water temp gauge in the garage, I'll dig them out and send some photos, can I have an email address or phone number to send them to? Ta
IM sent.
I have a full set of 70's gauges. They were set up for a gasser that was destroyed in a fire before they were installed. I traded for them in 1982 and am asking $300 if you are interested, water temp, vacuum, fuel. fuel psi, tach, 160 speed odometer oil psi. oil temp, amp, and clock. tach & odometer are 3 3/8 rest are 2 1/16
@58chevy I have sent you an IM about the gauges.
I have fuel oil water volts. No speedo 2 1/8 little sw logos all neg ground
- - - Following new post was merged to prevent 'bumping' within 7 days - - -
Oh snd nes fuel sender an temp sensors
I need the two guage st up for 40 forx pick up
