Hi im after a set of Rover V8 headers to go in a ford pop, tubular so i can modify if required, thanks Clint
Hi Neil, thanks for reply, I have been looking at those and they may be the way to go, it is a steering linkage issue... easier to chop headers than change steering ha ha What are you building or driving these days?
Clint - I've got these if your interested - I had fitted the "block hugger" style tubular headers on my Rover (also in a Pop) before changing for a set of original P6 cast manifolds (like you, to work around the steering issue - might be OK with your setup though)...they're a few years old, look a bit scabby but have done "zero-miles" and should clean-up....
Alternatively I have a set of SD1 cast manifolds that may work - I had started (nearly finished) removing the ugly air inlet pre-heater casting on the drivers side, otherwise these are in good condition, no cracks, just very heavy!
Open to sensible offers.....
Just out of interest, this is what my setup currently looks like (OK, its not as clean as this now!!)
