Various parts for collection from warden
Used S/S simmons straight through silencer, 2.5" bore, 315mm long, 185/115 oval, little use £15
Lug nuts 1/2" unf, double cone, 9 unused, 6 used once, £5
SSBC brake prop. valve, new £20 SOLD
Aluminium bonnet pins, pair new £10
Used 18 1/2" fan, heavy steel centre with s/s blades, £25
SCE copper 3" collector gaskets, one used once, £10
Pair used air cleaners, from 'hilborn' type scoop, 6 1/2" dia with chrome tops, £6
Small Chrome air cleaner, for strom?? new £3
Lakewood adjustable B/H dowel pins, .007" offset. Fitted in block once..wrongly labelled as .014" so removed, £40
Valvoline VR1 10.30 mineral oil, 9 quarts £35 SOLD
Used Header caps 3 1/2" one with lambda boss, captive bolts, copper gaskets, £15
BBC alt bracket used £5
BBC chrome timing cover, unused but slight rust on outside, £5
Brake proportioning valve please mate.
Sent from my SM-G930F using NSRA mobile app
I'll take the oil please. Could you text me on 07816390962 so I have your number please? Thanks
