Results 1 to 4 of 4
Thread: 1939/1940 Mercury & 1939/1940 Ford pedal assembly. LHD. Pre-Brexit price in ad.
    According to the numbers. First 2 pics are Mercury, 2nd & 3rd pics are Ford.
    Mercury is brake pedal 09A-2453 , clutch pedal 09A7519. Missing the 2 clips at the ends of the axle/shaft.
    Ford is brake pedal 91A-2455, clutch pedal 91A-7520.
    Also master cylinders that look pretty clean inside. Rubber footpads are good.
    Both assembly's 130 Quid each. Both will need new bushings. All CLEAN.
    Both assembly's are just over 5 kilograms each, makes postage to GB 25 Quid each. Usually takes 5 work days to get to your home from here in The Netherlands.. See my other parts for sale.............. NSRA thankyou
    pm sent
    thanks
    kev
    Ford pedals sold. Still have the Mercury pedals and master cylinder with the see-through plastic filler.
    Still have parts to sell. See my other ads. Maybe you can save on import fees before brexit hits.
