Originally Posted by
greengilbert
Chevy 350 sbc. Block casting no. 14010207. 1980-1985 build with 2 or 4 bolt mains.
Supplied and installed by Namco in Farnborough in 2015. I've done 10,000 miles since with two oil and filter changes and no problems.
Very slight oil leak at the back which could be either the oil pressure sender unit, the sump gasket or the rear crankshaft seal.
Oil pressure at 2000 rpm is 63 psi cold and 42 psi hot.
I'm fitting a performance crate motor so no ancillaries with the sale.
Engine is still in the car so can be heard running and driving.
see video.
https://www.youtube.com/watch?v=9luokkv-C4A
If the link doesn't work search 'img 3835' on youtube and it should be the second video result.
£800 ono
