I`m in need of a new pinion oil seal for my `46 Ford rearend!, the axle has a `Hot Rod Works` internals upgrade and open drive pinion adaptor.
The only way the old seal would come out of it`s housing was by force which has resulted in it being bent so It`s not possible to measure the internal or external dia.
It has stamped on it... USA CR21061.
Can anyone match these numbers with a UK available seal or recommend a company that could do a match and supply?.
Thanks for any help ...
