Seeking advice, again!! I am thinking of ways to mount the 32 Model B pickup GRP cab to the frame. If I lay 3mm thick webbing on the frame and bolt the cab to the frame using grade 8.8 m8 bolts into rubber rivnuts. The flange of the rivnuts is also 3mm so if holes are made in the webbing it will all sit at the same height. Is this solution feasible and if so how many bolts would you fit each side?
Many thanks in advance for your help.
Sent from my iPad using Tapatalk
