Hi again!
after two weeks on the car every day I stuck at the moment with a silly problem. maybe you have an idea....
I reassemble the drivetrain and everything went fine until I tried to bolt on the cover bell of the drive shaft (sorry dont know the exact english name).
there are the bell, a paper sealing or two and a kind of brass washer to align in the same direction to get the bolts in.
I will try to show a picture.
problem: I cant move that washer (4513) so there is no way to put the bolts in!
I loose the clutch, put in neutral, move the wheels, the engine EVERYTHING... nothing helps. everything is flooded with grease hehe
and also I am not sure wich bolts to use there. whats a Y-20900 ?
ANY help is welcome, thanks guys!
https://www.bilder-upload.eu/bild-4b...58492.jpg.html
-hope the picture upload is OK? -sry, I cant upload from PC
