Willy’s Coupe - £22,000
I’m advertising this for a friend who asked me to put it on here, I know no more than what the ad says so , if interested please contact Paul directly...
Description as follows.
1941 Classic Fabrications Willys Coupe bodyshell. Doors hung with original hinges, inside panels and latched. Hood is hinged with latch to finish, trunk is hinged and latched. Front fenders are fixed, rears are mounted and detachable. Custom door rain channels fabricated as original.
Full rolling CDS tube chassis front to rear with roll cage, 9" rear axle ( custom mounts, 4.11 gears, Strange 31 spline shafts, adjustable 4-link, coil-overs, disc brakes ). Jaguar XJS independent front suspension ( custom mounts, coil-overs, disc brakes ), custom all new propshaft.
Steering rack, proportioning valve, brake lines, electric fuel pump, fuel filter, fuel line, custom aluminium fuel tank, aluminium radiator, trans cooler, dual electric fans, battery mount, seat belt mounts etc etc all fitted.
Interior has sound deadening and heat shield fitted. Brackets for steering column, MSD module, brake pedal, gas pedal and shifter all fitted.
Dash is prepped for guages and ready to fit, modified mini heater, wiper rack and motor fitted, cut out switch.
Engine is Championship winning Chevy 427 big block from the original Honky Tonkin 57 Chevy of Jerry denning and Lee Pike fame. ( Lee kindly delivered it on the back of his pick-up from down south! ). Custom mounts, 4 into 1 headers, hi-torque mini starter, new chrome pieces. Side exit exhaust with Flowmaster mufflers.
Gearbox is new TH400, custom mounts, manual valve body, B&M Nitrous Holeshot convertor, Pro-stick shifter.
New parts from Willys Replacement Parts - Front grille, 2-piece hood trims, headlight buckets, headlight lenses and surrounds, door handles, original door hinges, rear lights, front bumper, rear bumper.
Wheels are Weld Pro-Star big'n'little with Mickey Thompson and Continental tyres.
Car comes with the following parts - Painless wiring kit, Flaming River column, Lecarra wheel, Autometer guages, dash switches, seat belts, Trick-Shift gearbox fluid, stainless hood latches, door swan neck mirrors, wiper arms/blades, Vintique interior mirror, Moroso air filter, Autometer fuel level sender and many MSD parts- 6AL ignition module, Blaster 2 coil, 8.5mm super conductor wires, socket dizzy cap, rotors etc.
HUNDREDS of hours put in to get to this stage - scratch built tube chassis, body mounting and alignment, engine/gearbox set up, front/rear suspension modifications and set up etc etc. Loads of receipts.
Price £22k
Any questions please ask. Paul 07732 354682. Email - paul41w@hotmail.co.uk
