Results 1 to 5 of 5
Thread: Window size allowance
    NSRA member falcon's Avatar
    Dec 2004
    Hi I’m going to get my windows cut on a Austin ruby . I’m going to make a template for them to cut the glass. I’m going to offer a card and mark round the opening . My question is how much either side do I add ( these are for the doors ) 5 mm to slide in I’m thinking. Thanks
    You need to make a ply template that fits your runners, fit and check it moves and seals as it should.
    Any other method is heading for failure.
    Dec 2004
    Yes you’re right thanks. I need to order the rubber ect cheers
    Small radius (1/2"???) on the bottom corners of the drop glass help prevent snagging.
    Dec 2004
    Thanks
