few bits wanted please
1937 8 or 9 or 40 ford drag link stock - just the solid part will do and the turn buckle = please
two dodge d100 front spring shackle bushings new 1'' od 1/2'' id and 2.5'' wide
pair of 14'' front shocks covered, have short open style to swapsies
36/7 ford headlight doofer bits under the lights - that are dropped already.
35/6 front bumper - rough and cheap have a 37 for trade
36 pickup front commercial grille - have a 37 and 38 to trade
want an s type getrag 221 gearbox and flywheel and clutch and starter. prop water pump, alternator, power steering pump.
x type jag v6 sump and pickup pipe.
st220 mondeo ecu, keys, loom, obd-2 port, transponder ring and under dash loom, fuel pump, tank, intake, maf and air box.
st200 2.5 style stainless aftermarket exhaust manifolds,
1936 commercial inner fenders same as 37.
1936 1/2 ton seat riser complete.
I have a power steering pump nob
