Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 239
Thread: One of these days T Truck
  1. #161
    Guest yjohnb's Avatar
    Apr 2012
    Well done , like others on here , really looking forward to seeing it out and about next year.
    John
  2. #162
    Well done!
  3. #163
    NSRA member Brian Eddison's Avatar
    Dec 2012
    well done mate, look forward to seeing it a some shows next year
    be quiet when you leave.... mr munn lives right around the corner
  4. #164
    NSRA member Knowledge's Avatar
    Apr 2004
    Got my registration papers back and been for my first drive.... unfortunately overheated, but nothing I can't solve. Otherwise here's some photos including one of the front undergoing modification to look like she should have in the first place. Grill would be black with a brass insert and that's a real 23 T bumper at the bottom.Name:  Test passed-reduced.jpg
Size:  210.2 KBName:  Dec-18 1-reduced.jpg
Size:  264.9 KBName:  Jan-19 1-reduced.jpg
    I know you think you believe you understood what I said, but I'm not sure you realize that what I said isn't always what I meant.
    My Intro '
  5. #165
  6. #166
    Apr 2012
    Brilliant, very nicely done !
    John
  7. #167
    Aye, well done, really please for you mate.
  8. #168
    NSRA member MisteR Tee's Avatar
    Fantastic, very well done Steve, now to get out there & enjoy it.
    MisteR Tee
    My Intro My website my cars
  9. #169
    Apr 2004
    In the pictures above showing the front of the car those headlamp surrounds I just taped on. So now the process of making them fit... although I don't know exactly where they came from, manufacturer wise these are obviously made to mount on brackets either side of a grill shell. To that end they come in 3 pieces with a front bezel, rear body and cap. After taking the deep breath I cut the backs off leaving enough for folding over, that lip will fit behind the plastic light mounts. After some hammering with a rubber mallet and a round lump of aluminium which I fortunately had that is almost the same size, the edges were folded over but with Crinkles. After annealing with a blow torch I hammered it flat with a large plate of aluminium on top and presto now I have two flat headlight backs ready to mount to the bulkhead.
    My Intro '
  10. #170
    Apr 2004
    That looks better. The set-up you see you on the front is only for this summer later I'll be adding Steel shell motometer and dog bone.as I do the full rebuild this winter.
    My Intro '
  11. #171
    NSRA member Graham Thompson's Avatar
    Sep 2008
    Quote Originally Posted by Knowledge View Post
    Good to see it 'in the flesh' at the breakfast meet last Sunday. I have to say it sounded great when you drove off.
    Sent from my SM-G950F using NSRA mobile app
    Rome wasn't burned in a night
  12. #172
    Apr 2004
    Rumour has it this car is undergoing a little bit of wood transplantation. ....
    My Intro '
  13. #173
    Apr 2004
    And so it starts. Looking forward to the finished frame. Will be nice to have doors with Windows! Those cut pieces of tree will soon be body frames.
    [ATTACH]42368
    Sent from my SM-T810 using NSRA mobile app
    My Intro '
  14. #174
    Apr 2004
    Latest. Mocked up samples. Gives you a bit of an idea of what's to come.Name:  20190924_120603.jpg
Size:  93.0 KBName:  20190924_120549.jpg
    My Intro '
  15. #175
    Apr 2004
    Ok so car is back from having the body made, now all the fun begins. First I need to add some metal inside to 'hold' the cab. The whole thing is strong enough but I want to frame it all aswell. Special thanks to Tony Davey at Smithys coachworks for the excellent work.Name:  20191210_141445.jpeg
Size:  114.7 KBName:  20191210_141546.jpeg
Size:  83.3 KBName:  20191210_141328.jpeg
    My Intro '
  16. #176
    Apr 2004
    Just sorted these.Name:  20191211_171643.jpg
Size:  76.0 KBName:  20191211_171650.jpg
Size:  91.2 KBName:  20191211_171701.jpeg
    My Intro '
  17. #177
    NSRA member RickyS's Avatar
    Jun 2012
    Will it remain a flatbed or are there plans for anything on the back? Liking the wood btw, would look great with some deep black gloss for contrast
    Sent from my ONEPLUS A3010 using NSRA mobile app
  18. #178
    NSRA member brading's Avatar
    It looks so much nicer as a " Woody " well done that man.
  19. #179
    Apr 2004
    Quote Originally Posted by RickyS View Post
    Indeed it will be a flat bed, with stake sides. The image below was while we were deciding the spacing. Ends of the boards are square with radiused corners now, and the bed sides are just a touch longer with similar ends as seen in the second pic from when I went to collect.Name:  IMG-20191107-WA0002.jpeg
Size:  44.6 KBName:  20191116_123420.jpeg
    My Intro '
  20. #180
    Apr 2004
    Was always the plan, the steel was just for a quick and cheap fix while checking out the handling etc.
    Quote Originally Posted by brading View Post
    My Intro '
